Results 1 to 8 of 8
Thread: Killer B pickup / STI pan instal DIY
    Cool Killer B pickup / STI pan instal DIY
    I installed a new STI pan and Killer B pickup for better oil control and peace-of-mind with the milage i'm racking up on the WRX and the horror stories I have heard about the factory pickup failing. I didn't want to be a statistic. And It wasn't too expensive to make happen.
    Parts needed
    STI dipstick (I bought it used off this forum)
    STI pan (I bought it used off this forum)
    STI oil baffle (new from Subaru like $8-10)
    Killer B pickup (Fred bean parts had the best price I found)
    my process
    1. remove intercooler (this is only to get to the pitch stop)
    2. undo pitch stop
    3. undo bolts on motor mounts holding them to the subframe
    4. jack up on transmission to gain 1-2" of clearance on back of pan for the rear 4 bolts on the pan
    5. remove driver side heat shield on manifold (if its still there)
    6. remover driver side motor mount (maybe not be needed)
    7. drop pan
    8. remove pickup
    9. remove baffle
    10. clean pan sealing surface on block
    11. install new part (I used lock tight on the pick-up and baffle bolts)
    pitch stop unhooked
    mount bolts removed
    4 rear bolts (you can't see them but they are there)
    raising motor - go slowly and be careful
    secret weapon
    removing 4 rear bolts
    pan removed
    baffle / pickup installed
    Scoobie Regular carmudgeon's Avatar
    Oct 2009
    Overland Park
    Nice write up, I thought about doing it myself when I bought mine but I was lazy and paid MKC to do it. The only issue I had was an oil leak that developed around the dipstick tube.
    I'm keeping a close eye on mine. it MIGHT have a SMALL leak on the rear of the pan. I'm keeping it clean and checking the under carriage often.
    It definitely isn't the easiest thing to do… but if it saves my motor its worth it.
    Anything that can save your motor is worth the cost and labor As long as its nothing that doesn't make any sense.
    2000 Honda Civic Si Coupe
    1.6 Liter DOHC B16A Motor
    5 Speed Manual Transmission
    Scoobie Expert Jagular1785's Avatar
    Jan 2010
    Iowa City, IA
    Nice write-up! Universal socket adapter is a must have if you aren't going to pull the engine. Be VERY careful jacking the engine with a wood block like that, I've had those split on me before.
    And KB pickup is awesome and a great investment for a long lasting engine whether you're stock or heavily modified. Their 7 qt oil pans are also awesome but IMHO not worth the 700$ price tag. Probably good for the lateral g's on track cars though.
    Chris
    Member of 100AW 2012,2013,&2014 Start Crew
    2000 Outback wagon
    1997 GF4 OBS frankenwagon- Sold
    2001 XL883C HD Sportster
    Very nice write-up, worth of 'tips and tricks'
    |l Josh D l|
    2005 SWP Legacy 2.5i Wagon - 30 MPGS YO!
    Thumbs up! Looks straight forward im going to start picking up some parts to make this happen.
    I was stubborn and decided to not raise the engine. But with the angle sockets and extensions I was able to do it. I would more than likely do it your way next time.
    John
    1995 Cosmos Black M3
    2005 Black STi(Sold)
    1998 Black Forester S(Sold)
    1993 Honda Accord EX DD
