Results 1 to 10 of 14
Thread: Request DIY write up's here!
    If you are looking for a write up or info on something, put it here!
    E92 335xi
    The bugeye headlight painting/cleaning is a pretty popular. Along with all others and clearing the headlights.
    #1 Top poster 19k and still posting
    The Official KCSubaru Ninja
    Quote Originally Posted by Anonymous
    Here is one of the links for the Koji mod on the bug eye's. For the most part it applies to also clearing the headlights and you can pretty much get the idea how to do the 04+ ones too. http://www.wrxfanatics.com/index.php?showtopic=1687
    ha that was me......
    Sorry not to clarify, I was hoping to keep this a KCSubaru writeup section, not so much post links from other peoples write up's.
    E92 335xi
    Quote Originally Posted by 12secsti
    Is there a real big difference? If it's good info it doesn't matter to me where it originates from.
    Quote Originally Posted by Justin 05 Sti
    Well, it would be nice to keep this section semi original, with writeups and pics by our members
    E92 335xi
    Scoobie Expert
    Apr 2005
    leavenworth
    i have a greddy profec b ( NOT the spec 2) that i wanted to install and see how it helps with my lack of boost problem. in the instructions, it says to tap into a fpr line, but i can't find pics anywhere as to which one. the best description i have found is "it runs along the top of the brake master cylinder". well, there's 3 lines all about the same diameter in that are. one that has the ufo looking doodad on it, then two other ones. i'm assuming the ufo thingamajonkey is it, but i'm not gonna start hacking into hoses without being 100% sure. if i could find this out, i would be more than happy to take pics and do a write up of the install.
    Quote Originally Posted by israel
    ...he looks at me real serious and said "my name is Razor."
    Mar 2006
    Sun City KS. (Mapquest that!)
    there are two fuel pressure regulators. the rising rate is on the passenger side, right above the injector rail, and it taps into the manifold with a two inch long piece of hose. the main fuel pressure reg is on the passenger side of the engine as well, next to the turbo inlet hose, on the front of the manifold.
    good luck.
    Why can't I turn sigs off?
    Scoobie Regular
    Jan 2011
    Cruising the Northland
    Re: Request DIY write up's here!
    Want to get a quick write up on removing the factory stereo in 2011 WRX. Different trim then the 2010.
    Not sure if this is a good place, but i need a DIY on replacing valve cover gasket? ive heard its a simple task but i just have very little knowledge of engines so any help would be appreciated
    [/HATE]
