Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: A new wagon in town / 04 san remo
    Well, its official I am now part of the subby crowd. I've been up to my eyeballs in hondas, so this is an exciting change. I've got some learning to do, but here are some pics / specs.
    ***** just updating some stats and pics*****
    2004 WRX wagon
    san remo red
    111k miles - 2.16.14 (owned since 75k)
    --MOTOR--
    STI intercooler
    custom intercooler sprayer
    Perrin Crank Pulley
    Perrin Y pipe
    snorkus delete
    turbo blanket + heat shield
    mishimoto radiator
    bellmouth downpipe
    up-pipe
    K&N dropin filter
    Killer B oil pickup
    07 STI oil pan and baffle
    --EXTERIOR--
    SRR painted side skirts
    STI scoop repainted SRR
    Custom Air splitter for scoop
    STI front splitters repainted SRR
    STI fog covers repainted SRR
    Sedan fenders repainted SRR
    tint
    front emblem delete
    plasti-dipped side mirrors
    front lip
    --INTERIOR--
    STI cluster
    STI shift knob (I'm a 6speed poser)
    short throw shifter
    factory steering column boost gauge
    forester rear cup holder
    retractable rear cover
    --HANDLING--
    2006 wrx 17" rims
    STI rear sway bar (i think)
    STI sedan springs
    Sagger butt spacers
    --SOUND--
    touch screen DVD head unit (bluetooth calling, iPod)
    stealth sub install (inside spare tire, under floor)
    upgraded speakers (6.5 components up front / 5.25 coaxial in the rear)
    6.5 sub under passenger seat
    --TUNING--
    ECU stage 2 flash - open source
    --MISC--
    STI key
    --Parts I have--
    TGV deletes
    3mm Phenolic Grimmspeed TGV spacers
    Gates Racing Timing belt kit / cam seals / cam bolts
    Equal length headers
    3 gauge pod clock panel
    --Things I need to do--
    power steering pump
    timing belt / cam seals
    roof rail delete - completed!
    Most recent pic
    (old stereo)
    Attached Images Attached Images
    Re: A new wagon in town / 04 san reno
    Looks sweet.
    With a DP it is likely your ECU has been flashed.
    Can you tell what PSI boost you are hitting?
    And WELCOME
    Subaru, it's all we'll drive!
    the car has the optional subaru boost gauge on the column. Its not in psi. I think mpa? I'll need to do some math to figure out the boost psi.
    I'm stoked!
    Quote Originally Posted by turbo sol
    I'm stoked!
    I know.
    I loved having San Remo Red when I had my Rex. The CV boot isnt hard. If it has been torn for a while, I would just buy a complete axle. Remanufactured can be found for about $70. Once you get the wheels off, and the rotors out of the way, itll just pop out of the tranny. May lose a little bit of fluid. Just stick the new one in, and put it all back together.
    Brent and I did the front passenger one on my leggy a few months ago, and it only took an hour or so. That included beverage drinking. Haha.
    Ryan
    '02 CMB E46 M3
    '14 XV Crosstrek Limited
    Scoobie Expert TunedAlready02's Avatar
    Mar 2009
    Loadin' up the choppers like its December 31st
    Nice buy. Shes purty
    Quote Originally Posted by cseaman View Post
    Within the first minute, I saw a guy with Oakley Gascans and a significant tribal tattoo. X'd out.
    Scoobie Expert Kilby33's Avatar
    Feb 2008
    Paola, KS
    Nice wagon! as for the key fob, I bought one off ebay. Look in your manual it will tell you how to program it. Really easy im on my phone or I would even give you a link how to do it.
    David - My 2004 STi
    "I guess if your car has a STi, it will turn you lug nuts green" - R U Faster Than A Redneck
    I just grabbed one off ebay (key fob)
    I didn't know they were programmable. Thanks for the heads up!
    Quote Originally Posted by Legacy
    They pop out, after you punch out the roll pin.
    and programming the fob:
    Program remotes: works on Alpine system.
    Unlock all doors, foot on brake, all doors closed. Cycle key quickly but carefully on-off appr 10 times until the car honks one time.
    Do not turn the key far enough to start the car, just to the 'on' position so the dashboard lights up.
    When the horn honks, open and close the driver's door, press any remote button and that's it.
    Program another remote? Quickly open and close the driver's door again and push a button on the 2nd remote. That's it.
    When you're done, remove the key and the horn should honk 3 times. You're all set.
    Sometime it takes more than 10 on-offs to set program mode. Open/close the door, lock/unlock etc, wait 10 minutes, then try again.
    Nice lookin' car...it's always good to see a red Subie. Paint your side skirts! What are your plans for the car? Do you have any?
    "Unlike Playstation, you can't just hit the reset button. Instead, you go through the pearly gates on fire." -Jeremy Clarkson
