Results 1 to 10 of 12
Thread: Daily driving 05 STi... part time race car.
    Jun 2013
    Lawrence, Ks
    After scouring through the other build threads I thought I would share my modest but enjoyable build.
    BUild specs:
    Engine:
    Aem intake filter for 350Z
    Ngk one step colder
    Grimmspeed PnP ceramic coated manifold/x-pipe w/ uppipe
    Invidia G200/ Invidia catted downpipe
    Cobb Stage 2 Ots
    Interior/exterior:
    Polk component speakers
    Kartboy short shifter kit w/bushings
    V-limited ebay style
    Suspension/Brakes:
    TiC fender braces
    Feal 441 7k/5k
    Whiteline ALK (comfort)
    Centric Cyro rotors (rear)
    Ebc Yellow stuff
    Alignment -2 Fcamber/ -1.8 Rcamber 0 toe
    Wheels/Tires:
    SSR GTV02 17x9 et45 w/ Bridgestone Re-11a 245/40R17
    Factory BBS w/ Blizzak LM-32 225/45R17
    First day home about 2 years ago. Stock as can be w/G200 as the only mod.
    [Img]http://i.imgur.com/MRKNDSMl.jpg[Img]
    Beginning mods were new Re-11s for the stock wheels. Then Cobb accessport and some Drag 31s for wintermode.
    New downpipe shortly to upgrade to stage II then noticed a whooshing noise in full boost.. found this.
    Replaced that with these. Grimmspeed pnp w/ x-pipe and a new uppipe as well.
    Attached Images Attached Images
    Jun 2013
    Lawrence, Ks
    Then onward with some Whiteline ALKs.
    Small sound system upgrade of Polk component speakers.
    Did some headlight restoration and added a V-limited lip.
    New Centric Cyro rotors for the rear w/ Ebc yellows.
    Popped in a new clutch after having some slipping issues in 3rd/4th gear under boost.
    Exedy 15803 stock flywheel
    Some new spark plugs(NGK one step colder)/passenger side valve cover gasket and a new radiator.
    Then I got some low w/ Feal 441s 7k/5k and a new set of wheels SSR GTV02 17x9 et45 245/40R17 Re-11As
    Also added TiC fender braces.
    Jun 2013
    Lawrence, Ks
    We do get around here are a few pictures in various places.
    Scoobie Expert Kilby33's Avatar
    Feb 2008
    Paola, KS
    she's a beaut! I'm a fan of polk audio I just don't have any polk car speakers. My home theater is all Polk though
    David - My 2004 STi
    "I guess if your car has a STi, it will turn you lug nuts green" - R U Faster Than A Redneck
    Jun 2013
    Lawrence, Ks
    Yeah I think they are quite good. Plenty better than stock that is for sure . Thanks for the compliments it has def been a labor of love over the last two years. Now just trying to find the direction for her. As autocross classing is becoming a forefront in her build currently.
    Still need to figure out sway bar setup but I am so conflicted on what would be the best setup. Don't want to buy something that ends up not working out. How are you liking your setup so far Kilby?
    - - - Updated - - -
    Current additions:
    Recaro sport seat.
    Plastidipped BBS for the winter months.
    Few shots for a photoshoot the other day.
    Feb 2008
    Paola, KS
    I like it so far. But I just did the rear. I'm conflicted on the front staying with 22mm or going to the 25mm I find mixed reviews for both lol
    Jun 2013
    Lawrence, Ks
    Pretty much the same boat I am in. Unsure what to do on the front and in between sizes. Bigger bar should keep the camber curve more intact during hard corner but how much is really enough.... These are the tough calls lol.
    I have an '05 STi that only sees track duty now. A 22mm bar works fine on the front. I've considered going to the larger bar, but increased negative camber in the front solved my push problems. I run the car at HPT and MAM and the car handles well at both tracks.
    In other news, I need to sit in that seat and see how it feels.
    Tim
