Results 1 to 10 of 11
Thread: FS/FT 97 Impreza Outback Sport with built EJ22 stroker- Project Car
    Scoobie Expert Jagular1785's Avatar
    Jan 2010
    Iowa City, IA
    The time has come for me to part ways with my beloved OBS. She still runs like a bat out of hell but I don't have time or money to get her up to passable DD status or to add the final touches to make this into a formidable track car. I'm also looking for another subaru that isn't so labor intensive, preferably a manual.
    Power(Build Thread: http://kcsubaru.com/showthread.php?5...build-97-OBS):
    EJ22t closed deck block (+ oil squirters)
    Wiseco stroker pistons
    EJ25d crankshaft (blueprinted for higher oil clearances)
    ACL tri-metal crank bearings
    Outfront H-Beam rods (rated at 150 hp per rod)
    12mm oil pump (JDM STI)
    EJ251 heads
    ARP headstuds
    Delta 1500 regrind cams
    EJ253 intake manifold
    WRX 440 top feed injectors
    Walbro 255LPH fuel pump
    AEM fuel pressure regulator
    Kinugawa TD06-SL2 20G turbo
    Bellmouth HKS catless downpipe
    Custom Spearco top mount intercooler
    Spec stage 1 clutch with Spec resurfaced flywheel
    Emanage Blue piggyback tuner with PnP harness (completely labeled and made by me)
    Stock transmission
    Rear disc brakes
    New timing belt kit (Gates) and water pump
    Suspension:
    KYB GR2 struts
    Stock sways and springs
    New rear wheel bearings
    The Bad:
    Needs a tune
    Rusty Quarter Panel spots
    Clutch chatters
    Tires are almost worn out.
    Chassis has~224k miles, Transmission ~ 175k, and engine/clutch has ~10k.
    Overall there is plenty of potential for this car and it pains me greatly to have to let it go. I don't have the budget or place to do the rest of the work to make this car what I wanted. The car is still a blast to drive and pulls quite hard despite running only 10 psi. I've put a good 5,000 into the engine, I'm asking 4000 OBO or trade (plus cash on my end for the trade, if necessary)
    Chris
    Member of 100AW 2012,2013,&2014 Start Crew
    2000 Outback wagon
    1997 GF4 OBS frankenwagon- Sold
    2001 XL883C HD Sportster
    Jan 2010
    Iowa City, IA
    Bump. This one's back up for sale. Looking for a 5 speed outback or fozzy. 4000 OBO.
    Call/Text 816-255-0441
    Chris
    2000 Outback wagon
    Scoobie Expert DanC's Avatar
    Jul 2005
    100AW Subaru Stage Crew
    Chris, have you thought about registering on the SpecialStage forum & listing it as a potential rally car?
    "Driving most supercars is like trying to manhandle a cow up a back staircase, but this is like smearing honey onto Keira Knightley." Jeremy Clarkson
    "The Suzuki Wagon R should be avoided like unprotected sex with an Ethiopian transvestite." - Clarkson
    Scoobie Regular
    Sep 2011
    Northland KC
    Wanna part with the off-road lights by chance?
    Jan 2010
    Iowa City, IA
    DanC- I have thought about that except the engine setup is not exactly kosher with a lot of the rules and regs. However that crowd may not care about making said setup kosher. I'll go take a look. EDIT: I'll be putting it up there as well when I'm approved.
    aksc- Most likely I'll be keeping those and putting them on the wagon I get to replace this one. Likely will be a leggy wagon so it should fit.
    Chris
    2000 Outback wagon
    Jan 2010
    Iowa City, IA
    New Pics added.
    Chris
    2000 Outback wagon
    Scoobie Newbie Rocket_88's Avatar
    Feb 2012
    KC Gravity Well
    That's a classic, Woody. We'll miss seeing her at the Rally. What kind of Legacy are you looking for?
    "That's like weaponizing a wind farm." ~ J. Clarkson
    '06 Baja Atlantic Pearl Blue "The Truck"
    '14 BRZ World Rally Blue "The Toy"
    Jan 2010
    Iowa City, IA
    I'm looking for a manual transmission subaru wagon, be it a legacy, forester or impreza. Hell a baja would be pretty sweet too, however I don't think I'll find one to trade into. Something that can haul a lot of stuff around and cruises on the highway decently well. While I won't be building the engine or anything, I am thinking about a bit of a lift if the suspension needs replaced.
    Chris
    2000 Outback wagon
    Scoobie Regular
    Sep 2008
    Olathe, Ks
    Damn wish I had the cash
    Jan 2010
    Iowa City, IA
    Sale Pending
    Chris
    2000 Outback wagon
